how about some hei help?
Discussion in 'The Garage' started by vortec, Jul 19, 2006.
  1. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    i've hit a few sort of dumb problems with my engine install, lately. of the big 3, air and fuel are fine, but spark is a issue. i have the "batt" wire and the larger harness with 3 wires that goes from the distributor to the cap/coil plugged in. i don't think there were any more wires, to begin with. what am i missing, here?
  2. K5ing in AZ
    K5ing in AZ Registered Member
    Aug 26, 2005
    32
    arizona
    hei help
    does it crank if it does pull a spark plug wire stick a screw driver in the boot then hold it against exhaust to see if it sparks if it doesent its your coil
  3. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    i tried a similar method, earlier witch would indicate either bad coil or no power to it. but i find it very odd, because the coil worked fine on the old engine. so, that makes me think i made an error hooking it up, this time. i just can't see what.
  4. K5ing in AZ
    Aug 26, 2005
    32
    arizona
    so it does crank. have you ever had a pickup coil go bad. cause if cranks and your sure the coil is good you have a bad pickup coil. it's the magnetic pointe thing in the bottom of dist.have to take apart the dist completly good luck
