how acurate is your oil gauge?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ahx, Sep 10, 2004.
  1. ahx
    ahx Registered Member
    Jun 27, 2004
    30
    Wayne, NJ
    I jsut finished rebu8ilding my 88 k5 engine and added a high flow fuel pump. when i step on the gas it swings to around 50 psi. at startup its pinned. at idle its only at about 4 or 5 psi. this seems quite low. anyone have similar readings?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What kind of gauges are you using?
    Mine are Stewart-Warner, and 2 1/2" or so, and 270* sweep.
    In a word, they're kinda accurate. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. ahx
    Jun 27, 2004
    30
    Wayne, NJ
    stock gauge.
  4. dmanblazer
    dmanblazer 1/2 ton status
    Sep 5, 2004
    165
    Wellington, Kansas
    I removed my factory guages and put Sunpro guages in their place, I still use my factory speedo and fuel guage.
  5. ahx
    Jun 27, 2004
    30
    Wayne, NJ
    how did you get them to fit into the dash. jsut cut the cluster behind the original gauge?
  6. J.R.
    J.R. Guest
    i checked my factory gauges and they are right on the money. but 5-10 psi at idle is low to me
  7. ahx
    Jun 27, 2004
    30
    Wayne, NJ
    yeah well i replaced the gauge and sender and i have about 45psi now. now i have to deal with my check engine light. and also my blown heater core. one thing right after another.
  8. dmanblazer
    Sep 5, 2004
    165
    Wellington, Kansas
    I took out the old guages and made the holes just big enough for the new guages, then I cut the bezel in half and just used the part that goes over the two big guages. Wired up my lights to the dimmer switch and whola it works it's lasted 4 yrs so far. I also did it to my 1980 Firebird, I used the mini guages.
  9. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I have the stock oil pressure guage and an aftermarket gauage in my truck. Normally the stock gauage is somewhat accurate, but I have seen it off between 10-15 psi before. The biggest problem I have with the stock guage is that it is not as responsive as the aftermarket guage.
    -Harrison
  10. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I have water and oil temp gauges out of a Catapiller 973 front end track loader /forums/images/graemlins/shocked.gif
