how are butterflies removed on a qjet
Discussion in 'The Garage' started by wazzabie, Aug 28, 2005.
  1. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    How do I remove the butterflies on a 4bb qjet?
  2. dyeager535
    26,978
    Best way is to grind the threads off of the exposed portion when you open them fully, then turn the screws out. If you don't, the heads typically break off, then you need to replace the shafts.
    I've got the screws out before without cutting the exposed threads off, but I took my time, and am probably just tempting fate.
  3. wazzabie
    Apr 17, 2001
    1,719
    5
    Washington State
    Why do I need to replace the shaft? I was able to remove the segments by using a vise-grip on the ends sticking out. Now I need to find the screws to fit this.. didn't see any at the hardware store. I'm I OK to still use the shaft? Is your concern that the stress I put on the shaft threads might cause the screws to become loose? What if I were to flatten out with a pin hammer where the threads come out. Might I cause damage to the shaft? Lots of questions here. Thanks for all the help dyeager535. I'm in Seattle also.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    He was implying that if you break the bolts the threads are stuck in the shaft and you have to replace it because you cant clear the holes. You seem to have gotten the holes cleared so there is no need to replace the shafts.
    Ira
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The screws are 3-48.
  6. wazzabie
    Apr 17, 2001
    1,719
    5
    Washington State
  7. wazzabie
    Apr 17, 2001
    1,719
    5
    Washington State
