How are your U-Joints???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hawglet, Mar 3, 2003.
  1. hawglet
    hawglet 1/2 ton status
    Aug 4, 2000
    265
    Hastings,NE
    I am just wondering if I keep getting a crappy brand of u-joint or what? I have put about 5 set in in the last 7000 miles or so. I have checked my angles, they are good, and had the rear shaft re-balanced. I only have 3 inches of lift with a locked 3.73 rear-end. Just wondering how often others had to replace and what brands you were using. Thanks.
  2. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    What brand are you using? If you are sure your angles are good check the shaft for dents and get it rebalanced.
  3. dyeager535
    26,980
    Your sure your yoke isn't worn out?
  4. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    hmmm the ones in mine now- have been in since '00 probably over 7000K on them....not a problem with them...
    Brandy
  5. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    A wise man once told me:
    "You can put in Spicers, or you can get good at changing U-Joints". /forums/images/graemlins/grin.gif
    Solved the problem for me! /forums/images/graemlins/thumb.gif
    -Ben
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    Carquest U-joints arent bad either, i put a f*ckin Napa U-joint, the cross over one that goes from the 10 bolt shaft to the 12 bolt rear end, and its already got play in it, the 10 bolt U-joint didnt, i think im gunna do the Yoke swap, i still have the yoke from the old ten bolt and the U-joint which is pretty new, can any one PM me with some kinda technique for setting up a yoke, if so that'd be great. /forums/images/graemlins/thumb.gif
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i got my yoke put on, and my driveshaft shortened for $55, professionally, i'd do that. brute force joints are pretty good.
  8. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    you might want to check if your rear U-bolts are lose if you are chewing up U-joints real fast. a buddy of mine had that problam and he spent A LOT of money on U-joints before he figured out that was the problame.
  9. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    well im a do-it-yourselfer, and i enjoy fixing things, and installing thins in my driveway, so im gunna start looking into it. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  10. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I have been buying 1 year warranty Brute force Ujoints for my rear shaft from Autozone and I replace them just before the warranty is up. I broke a few Napa 1350 joints before I learned my lesson. I'm pretty sure I could shape a few beer cans into a cross and get it to hold up better than the napa joints.
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Just a little tid-bit, those Brute Froce joints and the NAPA joints are both made by neapco. A bunch of other brands, too.
  12. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I believe the joints I've got are neapco as well. I haven't had any problems with them.
