How Bad Is It
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jc71355, Jul 20, 2002.
  1. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    How bad is this. Can I tighten it from behind the panel? It pops when I turn and I always thought that it was just part of the blazer but today I grabbed it and it feels a little loose, and there are cracks all around it. Does this mean I need a new panel welded in /forums/images/icons/frown.gif ? Or can this be tightened? Thanks ya'll
    James
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I believe you can get to it from behind the front seat if you pull the panel from the inside of the rear quarter but if it has cracks I would have a panel put in to fix it right it will eventually pull out of the panel.
  3. ol_grayfeather
    ol_grayfeather Registered Member
    Jan 15, 2001
    68
    Around Spokane, Washington
    Mines busted all out worse than that. I'm gonna try to weld the sheetmetal back up then put new hinge pin bushings in. The flat spot on top of the striker bolt is from the door sagging (hence needs new bushings) I dont know if you can get at it from the back side, havent messed with mine yet. Hope this helps
    Later
    Dan
  4. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Piece a cake. Take off the striker bolt and sand the area down. Then simply weld everything up and grind it smooth. A little filler and some paint and things will look nice. If you want to tighten it, then just stick a star head socket in there and go at it. I just use vise grips on the end anymore. Get some new bushings for your door hinges while you're at it.
    (K5s have the striker assembled sealed and can not be easily accessed. Only cut it open if the caged nut for the striker spins and won't tigethen.)
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Don't forget a new nylon roller on the striker bolt...makes all the difference in how the door closes. Definitely freshen up the door hinge, add new bushings and adjust the door as good as you can. The cracks don't look too bad, easily welded and ground smooth. When you tighten it up try and get the flat spot facing downwards.
    rene
  6. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Thanks for the help ya'll
