How bad is this?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jplagg, Oct 18, 2001.
  1. jplagg
    jplagg Registered Member
    Jul 23, 2001
    38
    Holland, MI
    I was pulling out of the garage when i noticed the front drivers wheel not working right. so i checked it andthis thing was not connected. How hard/easy to fix is this and what has to be done? you can see pics here.
    http://community.webshots.com/user/jplagg87
    its in the truck pics.
    thanks
    josh
    1987 GMC High Sierra 2500 4x4
  2. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Looks like a busted tie-rod end. Usually they unthread, but all that rust aint gonna make it easier.
    Mud, the ultimate paint job
  3. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Clicky... My Naval Fleet
  4. Tatman
    Tatman Registered Member
    Oct 2, 2001
    80
    Indiana
    Definitely a busted tie rod end. Good thing you weren't going down the road when it went. Nothing some WD40 and a BFH can't help you fix. And once you get the new one in I'd recommend having your front end aligned. And they can tell you how the rest of your components are doing and what needs replaced.
    Brian
    <a target="_blank" href=http://www.saddletramps.com/BlazerK5.htm>www.saddletramps.com/BlazerK5.htm</a>
  5. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    <a target="_blank" href=http://community.webshots.com/album/19192525LmAThqARXz>Clicky</a>
    Man that's a lot of rust.[​IMG] Maybe you should grease all those grease zerks avery once in a while.[​IMG] But it shouldn't be to bad changeing the tie rod end. Might as well do it all at once. Drag link ends, tie rod ends.
    <font color=blue>Esteban</font color=blue>
    <font color=red></font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/Estebans-album>Take A Gander At My Truck Here.</a>
  6. jplagg
    Jul 23, 2001
    38
    Holland, MI
    cool - thanks for the info. i've been meaning to get it greased up but havent done so. i guess now is a perfrect time :)
    thanks again
    josh
  7. Esteban86K5
    3,712
    Bakersfield, CA
    Well i gues in this case, "better late than never" doesn't apply.[​IMG][​IMG][​IMG]
  8. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    I figured it had to be a michigan truck with all that rust on it. thats one of the few axles i've seen that looks worse than mine. don't worry though its an easy fix. better check out everything including ball joints as well.
    Craig
    "Why is there a <font color=red>watermelon</font color=red> here?"
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Wow! That end looks like it just fell apart. It must have been VERY loose before it failed. Were you having a hard time keeping the truck in one lane? I can't imagine that it was easy to drive with it that badly worn. Thank your lucky stars that it didn't separate while you were blasting down the freeway at 70 mph! [​IMG]
  10. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    broken tie rod end ball joint , doh ...
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  11. Dip Stick
    Dip Stick Registered Member
    Oct 14, 2001
    73
    Murdock, Florida
    Damn, and I thought my truck had alot of rust on it. I feel much better now, thanks. 8P
    It's not what you drive, it's how you drive it.
    1986 K20 350 700R4 208
  12. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Don't forget LFH in addition to WD40 and BFH. Whats LFH you say? Well, Lotta Freakin' Heat. I know everyone doesn't have access to a cutting torch but heating things up cause the metal to expand and come off like cake. You just gotta know where to put the heat so you don't weaken anything.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  13. aaaaggh
    aaaaggh 1/2 ton status
    May 4, 2001
    161
    birmingham alabama cause there no ham like birming
    ever heard of vehicle maintainance?
    good grief ive never seen that much rust.
    would you mind un-wedging your fullsize from between those trees? your blocking the trail.
  14. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    your lucky it fell of in the driveway. Had one fall off on somebody else's car while I was driving it turned right in to a parking lot and fell off. 5 mph and the steering wouldn't respond
  15. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    That's why I love AZ...my '82 and my '91 still have paint on all of the undercarriage that originally had paint! No rust on my trucks!
    The learning curve is a toll road...ride with someone who has already paid!
    <a target="_blank" href=http://photos.yahoo.com/abshort1>My Naval Fleet</a>
