How bad will turning be with a welded front end???
Discussion in 'The Garage' started by Flexy K20, May 8, 2003.
  1. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    I was just curious exactly how bad the turning will be with a welded front end. I know it really kills turning, and I will have to unlock a hub for turns, but will I have to on smaller ones? Will I have to unlock a hub for every little turn on the trail or just the bigger ones? Thanks
    -fLeXy K20
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you should only have to do it on tight turns
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Don't know about the "Lincoln Locker" variety, but mine with a power lok posi, jump's around a little. /forums/images/graemlins/eek.gif
  4. alesko
    alesko Registered Member
    Apr 27, 2003
    47
    sw pennsylvania
    I ran a welded front on a pulling truck and couldn't make the turn out of the arena without unlocking a hub. Other than a mud bog or a straight shot I wouldn't weld another front.
  5. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    I had a welded front a few years ago and hated it. The steering was harder, couldn't turn sharp, was hard to unlock the hubs and hard to get the tcase out of 4x4. I would for sure go with hydro assist with a welded front to take some of the stress off the steering linkage. Just my $.02
  6. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    It makes turning alot more difficult with both hubs locked, and is very hard on steering components. I welded my front about 6-7 months ago, I only lock both hubs if I absolutely have to, if I need a little extra traction I just lock one side. If you have a heavy right foot like I do then get ready for some carnage. But the added traction of all 4 tires digging in is awesome /forums/images/graemlins/grin.gif.
  7. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Years ago, I was running a welded D44 and 38's. With the hubs locked I only had about 1/3 of the normal turning radius. When wheeling I used to keep it in 2wd and 1 hub unlocked to move around on the trails.
  8. Flexy K20
    Oct 22, 2002
    398
    Bay Area, CA
    I really want the front locked but still wanna be able to drive on trails without unlocking a hub for every single little turn. I dont really care about welding you the gears because they are 4.10's and I am going with 4.88's and an ARB in like 4 months. I just wanna be locked up front until I get that. What do ya say...weld it? or leave it open? Thanks
    -fLeXy K20
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Lockright. Cheap, easy, turning isn't terrible, and you can resell if after you are done with it.
  10. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    If it's just temporary, weld it. If you don't you'll probably always wonder if you should have done it. Worst case scenerio is you wont like it but you're going to be replacing it soon anyway.
  11. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I've ran a welded rear axle in my Blazer for several years but just couldn't bring myself to weld the front even though it would have been free. Finally went with a Lock-right when I swapped in the front 60, used to run an Eaton posi in the old front 10-bolt.
    So far I have been on 2 trailrides with the Lock-right and I honestly don't think turning is any worse than with the posi.
  12. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I was gonna weld my D60 before adding a locker but Crawln73 made me an offer on a Powertrax no-slip that I couldn't refuse so I never had a chance to do it. "Boy Am I Glad It Worked Out That Way!". If I'm coasting down a hill under no power it slips just enough to give me about 90 percent of my open turning ability, with any power applied, that mostly dissapears and no matter how much the wheel is turned, it only turns about 30 percent of open. I run mostly in 2wd low these days and only engage the front end on the hardest stuff, it works out well this way, but I wouldnt want to get out and unlock a hub each time.
  13. Flexy K20
    Oct 22, 2002
    398
    Bay Area, CA
    I have an extra set of spiders, how hard are they to change If I dont like it? Thanks
    -fLeXy K20
