How bad would it be to run atf through a hydralic assist system?
Discussion in 'The Garage' started by white-rhyno, Oct 20, 2003.
  1. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I have ran atf in my steering for three years now. Now that i got the ram installed im having second thoughts about running atf through the ram, should i flush the system with power steering fluid? I know it is a heated debate about atf and power steering fluid in a normal system but what about when you run a ram also??
    Brad
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i didnt know there was a heated debate, not wanting to steer this post off course, whats the benefits of each?
  3. gmule
    gmule 1/2 ton status
    Apr 2, 2002
    196
    Conifer Colorado
    I also have a question regarding synthetic vs regular fluid and if its ok to mix. If you can't mix 'em whats the best or easiest way to purge the system.
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    ATF and power steering fluid are basically interchangable in a power steering/hydraulic setup. They are both hydraulic fluids. ATF is special in that it is formulated to work with the clutches in the tranny. I have run several hydraulic rams off ATF with no side effects (1 dump truck, 2 dump carts, hydraulic liftgate and a crane) and used it in all my power steering setups with no ill effects. If it's only performing a hydraulic function then fluid is fluid. For instance one of our dump trucks has used tranny fluid for years, but now one of the cylinders is goind bad and no matter how much we repack it the thing still leaks. So we now use tractor hydraulic fluid because it is thicker and doesn't leak as much. Downside is it's slower in the winter time when the fluid is cold.
    It's when you add in stuff like tranny clutches or or tractors that use the hydraulic fluid as transmission lube that you have to be specific what you put in.
  5. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Wrong. It makes the softer seals used in automotive set-ups hard and brittle. It isn't good for them. Just put steering fluid in it. Why pay a load of money for a hydro assist set up, then jeopardize it by running ATF so you could save $.50?
    Don't mix synthtic and non synthetic. They don't mix and where the barrier is between the two, heat will build up dramatically.
  6. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yep, when I was speaking with Jeff Howe of Howe Performance last week he said never to run ATF in a steering system and if you run it in one of his he will not waranty anything. Synthetic PS fluid is the only thing you should run.
  7. 4X4HIGH
    Dec 14, 2001
    22,058
    69
    Pleasanton, CA.
    Most GM vehicles recommend dextron III ATF in the power steering system. /forums/images/graemlins/confused.gif
  8. white-rhyno
    Jan 27, 2002
    942
    Thanks for the info guys. Im going to flush my system before i hook up the lines tomorrow.
    Brad
  9. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    i didnt know there was a heated debate, not wanting to steer this post off course , whats the benefits of each?
    ahh man, thats the worst pun I have seen on ck5 in years!! tell me that was intentional!! /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
    j
  10. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    I am only speaking through experience and a 25 year old truck with the same power steering system right down to the hoses that use ATF. People will find there is a big difference between theory and actual use. My actual use stems from the fact that with 3 trucks, all with hydraulic equipment on em, 2 tractors and a backhoe, and 2 dump carts it is more about how many fluid containers you have around rather than the money. I would rather use ATF on all the equipment that can use it and save having to stock power steering fluid as well. Also many hydraulic pumps and rams specify using ATF as fluid, so with your theory they should not use ps fluid right? No, the big brain pan scientists can say what they want but in my EXPERIENCE, which is considerible in this area, for hydraulics fluid is fluid unless it has to perform some function other than pushing a ram.
