how big a tires can i get?
Discussion in 'The Garage' started by jj4465, Aug 6, 2003.
  1. jj4465
    jj4465 Registered Member
    Jul 31, 2003
    19
    Nebraska
    i was just curious what the max for tire size is with no lift...and whats the max with a 3 in lift...approx? thanks
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    33's with no lift and with 3in lift well do you want to trim the fenders some? i have 38's with a 2.5in lift /forums/images/graemlins/thumb.gif
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    depends on if you want to trim or not... with a little bit of searching this answer will be found... it ranks in at about third in the "answered all the time questions" right behind "How to beef up a dana44", and "Will one ton axles bolt up to my rig" /forums/images/graemlins/thumb.gif
  4. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    **grabbing popcorn**
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Ive seen 44's with 1inch lift
  7. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    It really all depends on how scared of cutting sheet metal you are.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Are you willing to regear or swap your axles ??? Best thing too do is just drive it like it is till you decide what you'll be willing too spend more money on. My understanding is you wanta go 3" becouse you don't wanta get new drive shafts. Correct me if I'm wrong. But anyways, you can't go slap on big tires with 3:08 gears and not expect too burn out your automadic transmission. If you're going too do it, do it right. First decide how big of tires you want, 35's are a good place to start.
    Then get a lift (or fender trim) big enough too clear those tires under full flex. Next either swap in a set of axles with the propper gears, or regear the axles you already have. Then you can bolt on your big tires. If all that sounds like more then you want to do, you could alway sell the truck.
  9. Fletch79
    Fletch79 Registered Member
    May 14, 2003
    63
    Southern Wisconsin
