how big is my gas tank?
Discussion in '1982-Present GM Diesel' started by 82K5_6.5L, Mar 31, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    curious, i want to know how big my gas tank is...my friend has a 90' Burban and its got a 31 gallon tank..took 56 dollars the other day to fill that thing up..im thinkin mine is close to the same...
    also, was just reading, what would a trans. cooler do on my 700??
    thanx guys /forums/images/graemlins/k5.gif
  2. schlechto
    schlechto Registered Member
    Aug 4, 2001
    56
    Carnation, WA
    Run your tank dry and then fill it up /forums/images/graemlins/shocked.gif
  3. Crunk_K5_1984
    Crunk_K5_1984 Registered Member
    Feb 5, 2003
    87
    Kosciusko, Mississippi
    Im not sure running the tank dry would be a bright idea... ESP. on a diesel. But I think you have a 27 gallon tank, if I'm wrong, someone will correct me.
  4. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    hold on a second..i heard if u run ur diesel out of gas it will "F" it up bad..it will seize ur engine..thats bad.. /forums/images/graemlins/ignore.gif
  5. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Run it down to 1/8th of a tank. Fill it up. If it takes over 25 gallons you have the larger 31 gallon tank. If it takes between 20 and 23 gallons you have the smaller 25 gallon tank.
    You can always go measure how far down the tank hangs from the frame. The 31 gallon tank on my 81 Jimmy hangs down 7 1/2" from the bottom of the frame. The smaller tank is the same length and width, just not as deep...
    Rene
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Rene
    Hey Rene
    I thought the same but I was reading the other day and it said the 6.2l blazer came with the 27galon tank, only option.
    I would like to do more searching to confirm.
    I have the 31 galon because mine is converted from gasoline.
    The 40 galon only came on the Suburban because they have a little more overhang to fit it.
  7. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Mine has the 31 gal, came stock. It says so on the sticker on the drivers side fender.
  8. Crunk_K5_1984
    Feb 5, 2003
    87
    I think all civie K5's came with 31 gallon tanks and the CUCV's came with 27 gallon tanks. I'm pretty sure, but not 100%. /forums/images/graemlins/crazy.gif
  9. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    ha, i just found it.. it was on one of the stickers in my glove box..comes with a 31 gallon tank.. it looks like the original sticker from the factory, its got all the specs,gear ratios etc.. on it... will have to read it more..
  10. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    That makes sense, becuase the source of my info was for the CUCV's
    /forums/images/graemlins/thumb.gif
  11. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    You got a GAS tank on your Diesel? Hrm? My tank Diesel tank is 31 gallons...and it took 31 gallons to fill it when it was empty, not fun.
  12. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    Well these guys have your tank size nailed, in regards to your tranny cooler it will greatly extend the life of your 700r4. /forums/images/graemlins/thumb.gif Heat /forums/images/graemlins/angryfire.gif is the #1 failure of transmissions over time. Especially the 700r4 I believe. correct me if I'm wrong.
