How big is too big on transmission fluid lines?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grumpy, Feb 18, 2003.
  1. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    What ID would cause an excessive pressure drop? I am installing an aftermarket trans cooler and wondered about the size of the line.
    David
  2. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    The oil flow for the cooler runs thus..
    from the outlet in the converter...to the cooler, back into the case for transmission internal lubrication..
    You cannot make the lines TOO BIG for functional reasons, because there is the case restriction in and out of the trans...You can make them TOO SMALL
    The flow through the cooler is limited in any case, and rarely exceeds 35psi
    The problem with very large lines, is they do not give up enough heat...a smaller line actually does better..(more area per volume)
    Staying with the stock diameter is probably best...
    /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
