How big of a difference will it be
Discussion in 'Other Rides' started by Z3PR, Mar 14, 2005.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Okay, most of y'all know I have a 78 El Camino with a factory original 305. When I can afford it I plan on a 350cid 290hp GM crate engine. How big of a difference will that be ?? I have no idea what the factory HP and torque rateing is for the factory 78 305. I also have no idea what the factory rear end gearing is, but I also plan on a posi rear with 3.73 gears, and a 700r4 transmission. I think that combo would be a great match. So anyone have any advice or comments ??
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    motor, gears, everything, I think you will be very happy with it. My 305 to 350 swap was a good jump in power in my K5. That was mostly torque gain though and with 2.73 rears it still sucked. With gears that would have been awesome. Will you see a HUGE jump, I don't think so, but all put together it should be a little rocket.
  3. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    those g bodys flex big time and need some extra stiffeners added to help body twist . my friend runs them and his 87 monte ss was big time flex off the line and we put in 6 point cage and wow big improvment. he also runs air shocks rear with at least 50-60 psi for traction help. this is all at the track 1/8 and 1/4 miles
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  5. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    what size tires are you going to run? I plan on 3.55 with 275/60 tires with my 700R4 in my chevelle. just a thought.
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I'm guessing your 305 was rated at no morre than 180 horses. You will notice a vast improvement in acceleration, with probably the same mpg.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I want too go with 16" rims because I plan on upgrading the breaks. I'm not sure on tire size. I do want the same size tire on all 4 corners. I'd like the widest tires that will fit without any rubbing. Front will be lowered 1.5" to 2", and rear will be lower 1".
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm getting phyced about that crate motor.
    After the warranty runs out, think a pair of Dart Pro-1 heads, and a Comp Cams 270-H magnum camshaft. What do you think that would bring it up to ??
