how big of tires can i put on??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88k5blaza, Oct 30, 2002.
  1. 88k5blaza
    88k5blaza Registered Member
    Oct 17, 2002
    70
    new hampshire
    ok i have a stock 88 k5 with no lift of anything and i was wonderin how big i could go and still get all the suspension travel so i dont rub on the road i dont care about off the road but on i dont want them runnin when i hit bumps and stuff
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You don't care if they rub off road? So you don't mind shredding brand new tires? 33s will fit with very minor trimming, they probably won't rub on road, but may hit the corners of the fenders off road. 35s will fit if you don't mind hacking the bejesus out of the fenders. </font color>
  3. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    alot also depends on teh wheel you use. If you go with a 33" tires on a 10" wide rim you will rub alot more that if you ran a 8" wide rim
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I have an '87. I've been running 33x12.50 15R BFG MT on 15x8 rims for the last five years, stock suspension. At first, I had some rub on the right front fender, front edge. Adjusted the steering stops, no more problem. I can rub the front end while wheeling, no problem. June was the first time I had rubbed the back tires, I was in Hollister. If you do mild wheeling, you are not going to have any serious problems. If you wheel a lot, then do some fender. BTW, I might be getting ready to step up to 35" in a few months, and then it will be jigsaw time.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you could probably run the largest Sears Road Handlers they make, no problem /forums/images/graemlins/smirk.gif /forums/images/graemlins/rolleyes.gif
  6. 88k5blaza
    Oct 17, 2002
    70
    new hampshire
    well i dont really want to cut the fenders too much and i have 10.5 wide wheels so 33 are lookin like the biggest i can go i guess? if anyone else has any suggestions feel free i dont go wheelin that much so anyone in the same boat let me know!
    /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Would you consitter a small lift like a 2" or 3" body lift, or a 2.5" or 4" suspension lift ??? I went with a 6" suspension lift, now I'm consittering adding a 3" body lift. Current plans call for either 35" or 36" tires. But I do off road every chance I get, and plan on being able to FLEX.
  8. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    How much you use it, what kind of suspension you are going to run, and how much you trim will make a big difference. With no swaybars and 4 inches of lift, my 33's touch the back INNER fender of the front on my K30. Yes, 33's. This is also as a rear tire is hanging in the air, but still, I was a bit surprised.
  9. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    44" Boggers. They'll fit like a glove
  10. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    I just put on new wheels and tires. 15x8" and went up from 31-10.5 to 32-10.5 last month. It looks and handles great and no chance of rubbing on a stock rig.
    Backlash
  11. 88k5blaza
    Oct 17, 2002
    70
    new hampshire
    thanks for the help and i would like to keep it stock with no lift i just wanted some bigger tires because the 31's on it now look lost in the wheel wells
