How bulletproof?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by deothrwhtmt, Jul 8, 2002.
  1. deothrwhtmt
    deothrwhtmt Registered Member
    Feb 24, 2001
    61
    Maryland
    Just how much can a NP205 take?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Lots, more than most people can give it. I'd guess upwards of 500 ft/lbs, probably quite a bit more. </font color>
  3. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i've only seen/heard of one 205 breaking, that was a furd f100 in TTC a few yrs ago. because the front axle moved back, the driveline moved back and cracked the case where it mounts to the tranny. but none of the gears broke.
  4. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    the only real weakness I have ever heard of in a np205 is in the ones that have 10 spline front outputs. Upgrade that bad boy to 32-spline and the 205 plenty ready for 500+ ft/lbs.
    J
  5. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    THat and the 10 spline INPUTS! Can't forget about rounding those bad boys off! /forums/images/icons/grin.gif Stay away from the 10 spline thing!!! You won't be able to break it! There's a reason I've converted all my 208 to 205s and this is why: NO CHAIN! CAN'T BREAK IT!!! I've bought 205s off of `70 trucks that look brand new on the inside because they're all gear! Best transfer ever made! /forums/images/icons/cool.gif
  6. muddysub
    Jun 23, 2001
    10,452
    489
    except for the worthless low range. /forums/images/icons/frown.gif
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    How good is the low range in a busted T-case? /forums/images/icons/grin.gif
    Rene
  8. Batmanjr
    Mar 23, 2001
    1,537
    How do you mean worthless low range? I think 2:1 is plenty low for a stock transfer!
  9. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have seen one that blew the guts out. It took about 1200hp in a pulling truck to do it though. I think just about anything a normal person throughs at it won't be a problem.
  10. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    All I know is that they are strong. /forums/images/icons/smirk.gif
  11. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    the 205s low range isnt the greatest... it would be nice if there was a way to make it 4 to 1 by swapping gears or something... but hey... cant have everything!! /forums/images/icons/laugh.gif
    j
  12. Grim-Reaper
    7,385
    Atlanta
    I got a Bud that managed to blow the back off one on his Bronco. He's a tallented guy though. He blows up D60 fronts all the time. I think he has a 460 mildly built in it.
  13. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Put it this way they can and do break, but mostly due to lack of maintainence and/or excessive (more than most of us will see HP/torque). Different spline counts have different strengths but overall it is the strongest stock (and in most cases stronger than the aftermarket) t-case you can get.
    In the truck pulls I have seen several adaptors break (mine included) but the case was fine and I've seen one front output shaft snap and one rear output shaft snap (built 454) after pulling one front wheel off the ground........TORQUE!
  14. ratpack7
    ratpack7 Guest
    " the 205s low range isnt the greatest... it would be nice if there was a way to make it 4 to 1 by swapping gears or something..."
    I thought that was the whole idea behind the duobler?
  15. deothrwhtmt
    Feb 24, 2001
    61
    Maryland
    Good so what you guys are saying is, if someone were " smart" enough and decided that they were going to run top loaders and terras it wont go up. At least I can reassure his gf now.
