How can I fix my leaky slip yoke seal???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fad2blk99, Jun 19, 2002.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I've had this problem with a previous Blazer. I replaced the the leaky rear seal (I even dabbed a little silicone around the lip before pressing it in) but the leak continued. Now I've got another Blazer (actually a Jimmy) and this leak is even worse! Any of y'all have any tricks for fixing this???
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i just went and bought some trasmission stop leak and put it in...fixed my leak in about two weeks.
  3. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    I try to shy away from that stuff. But you say it worked okay for you? I may try it anyway, cuz there are a couple more leaks here and there, the slip-yoke being the worst. On the other hand slinging all that ATF under the truck helps keep the rust down on the floor pans /forums/images/icons/laugh.gif
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    You might want to try a new slip yoke & seal. A Dana/Spicer yoke and Chicago Rawhide seal cost me less than $20 about 5 yrs agao, I doubt its gone up much.
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    bigjbear might have a good idea...your yoke might have a groove worn into it causing it to leak even with a new seal in the case...
    Later
  6. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Sounds good! Where did you get the yoke and seal from?
    Thanks!!
  7. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I got mine from a drive shaft shop in Savannah,GA (where I lived at the time)
  8. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Thanks! I'll it try.
