How can I fix my Speedometer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Nov 15, 2000.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    It's not the speedometer, it's the little plastic gears in the NP205. They're hashed. I have not been able to find the replacement plastic gears that go in the tcase for the speedo. I thought about going to the dealer, but I also want to correct the speedometer for bigger tires.
    Does anyone know the formula for figuring out speedo gears? I have 3.73's ratio and want to correct for 36" tires, which should actually be 35" tall in real life.
    Anyone?
    -- Mike
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Find someone who's sppedometer you trust, or have a cop clock you when yours says you go 55. find out what theirs says. For every 2 mph you need another tooth. So if when it says your goind 55 your really going 63, then you need a gear with 4 more teeth than the one in there has.
    90K5
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    A dealer will have a book and will get you close.
