How can I get a reduction in power assist?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, May 29, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    I don't like how easy it is to turn the wheels. I was wondering if there is any way to modify the pump or box the put out less assistance. I kinda got used to driving with the belt disconnected, I loved it except for when I was stopped or at a parking lot trying to manuever at low speeds.
  2. nash69
    nash69 Registered Member
    Mar 18, 2002
    24
    nj
    ther is a nut and allen bolt on top of the steering box. by holding the nut and screwing ht eallenbolt in you can reduce the amount of assist.
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Go <a target="_blank" href=http://westtexasoffroad.homestead.com/powersteering.html>here</a> and reverse engineer this modification.
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    That adjustment is for the over center adjustment, if you screw it down to far it will make it harder to turn, but not reduce the amount of assist, and can harm the box, its along the lines of running a gearset with too little or no backlash, the gears mesh too tightly and can be damaged.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    To do it properly you would need to change the torsion bar inside the steering box itself. Give the guys at Lee Manufacturing (818) 768-0371 a call. I can't find a web site for them, but they can steer you in the right direction.
  6. dyeager535
    26,980
    You can change the valve in the power steering pump. They seem to be pretty much universal no matter the year (as long as the pump itself physically looks similar) and there WERE two different valves, at least for the trucks. I would expect V6/V8 RWD mid 80's GM cars/pickups (S10's) to have different valves in some cases as well. IIRC, the C/K valve difference was manual vs auto transmission.
    Not sure what my pump came off of, but it requires more effort than my dads truck, with similar size tires.
  7. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Best thing to do is weld up your front spider gears and leave the truck in 4 wheel drive!!!!!!
  8. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    My buddies '72 had the same "problem" so he just put a smaller Grant steering wheel on. Less leverage = less assist or somethin' like that
