How can i get the door handles off????
Discussion in 'The Garage' started by Capnscoop, Apr 22, 2007.
  1. Capnscoop
    Capnscoop Registered Member
    Mar 25, 2007
    43
    South Florida
    ive got them unbolted and off the door but they are still conected with a rod inside the door and i cant figure out how to disconect it...
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    There is a little plastic (sometimes metal) clip that needs to be flipped up out of the way so the rod can be disconnected.
  3. lectric80
    lectric80 3/4 ton status
    Apr 4, 2007
    9,508
    Grantsville, Ut
    The rod should have a clip on the end of it. Usually it rotates off the rod then the rod can be removed. We always called them carburator clips. Basically it is a round hole that the rod pushes through then a clip that is attached to it that kind of flips down over the rod. That way the rod can't pop out. It is kind of hard to describe, but the LMC catalog has it on page 24 of the current K5 catalog
  4. Capnscoop
    Mar 25, 2007
    43
    South Florida
    ok...there is a clip where the handel connects to to the rod but it dosnt seem as it if it will let it come off??? should the rod come out with the handel???
  5. K-5 Bomber
    K-5 Bomber 1/2 ton status
    Aug 20, 2006
    108
    Northeast California
    Negative, the rod does not have to come out with the handle. Just apply downward pressure with your thumb. You should be able to feel a somewhat sharp edge along the top of the rod. That is the clip. Once you pop it off, you can remove the rod by pulling it toward the inside of the door. It can be kind of a PITA.
  6. Capnscoop
    Mar 25, 2007
    43
    South Florida
    still cant get them off....any other words of wisdom??? i cant find the clip inside the door??? and i have the windows and door panels out...im stu:confused:ck
  7. Capnscoop
    Mar 25, 2007
    43
    South Florida
    Help!!!!:1zhelp:Help!!!!
  8. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    just got done removing mine. gotta take a pick tool, and pull on the lower edge of the metal clip to get a small tit out of a hole, and then it will slide down with a screwdriver to allow the rod to come out. I always wear those medical rubber gloves when working in there, keeps me from cutting my hands all up.
  9. Capnscoop
    Mar 25, 2007
    43
    South Florida
    finally got them off....what a PITA....thanks everyone:bow:
