How can I ID my tranfsfer case? NP205, etc?
Discussion in 'The Garage' started by platapus, Jan 21, 2007.
  1. platapus
    platapus Registered Member
    Jan 15, 2006
    37
    CALIFORNIA
    How do you tell what transfer case is what? Can they me IDed by apperance (such as trannys TH350 / th400) Are transfer cases stamped?
  2. Currank5
    Currank5 1/2 ton status
    Apr 4, 2006
    244
    South Dakota
    Theres a circular metal disc on the back of the transfer case that will have the model number stamped on it.
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    205 t case is best identified by a small circle on the backside with 3 bolts holding it on. About 2" in diameter.
    There is sometimes a tag on the back of the transfercase to tell you what you have. Alot of times its missing.
    All aluminum, 208 or a 241.
  4. goldwing2000
    goldwing2000 Guest
    Just post a picture and somebody on here will tell you. :D
  5. platapus
    Jan 15, 2006
    37
    CALIFORNIA
  6. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    that is one GIGANTIC picture of an Np203
  7. platapus
    Jan 15, 2006
    37
    CALIFORNIA
    NP203? Are they any good? I dont know much about the different types of transfer cases?
    Sorry for the hugh pic.
  8. goldwing2000
    goldwing2000 Guest
    There ya go!
    And now cut that picture resolution in half (or quarter)! :eek1:
    They are a full-time 4wd case. Decent in strength but not really good or bad.
    Just different.
    It can be converted to part-time 4wd but for the expense and effort, it's easier to switch to a different case.
    If it's already been converted, then... *shrug* run it till it breaks. :)
  9. platapus
    Jan 15, 2006
    37
    CALIFORNIA
    Someone has already converted it, and added warn hubs.
  10. goldwing2000
    goldwing2000 Guest
    Good enough. Run it till it breaks and then convert to an NP205. :D
