How can I make my 84 ride better
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sting, Oct 9, 2001.
  1. sting
    sting Registered Member
    Aug 14, 2000
    31
    I have a 84 with stock suspension and new rancho shocks is there any thing I can do to
    make it ride smoother.....stock rims and 31 inch tires...which is stock as well
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Ride better how? What do you not like about the way it rides now?
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. J.R.
    J.R. Guest
    depends how much money you want to spend. you can replace springs, and depends on the rancho shocks but some of them can be rather stiff for a ride. there are some other brands of shocks that ride better then rancho but are more money also.
    BIG BLOCK MAN
    "MORE POWER"!!
  4. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Replace all of the spring bushings with replacement ones from energy suspension. Or see if ORD makes factory replacement with greaseable bolts. That will make for a smoother ride. I just replaces my rear spring bushings on my 83 with energy sus. and the ride is completely different. I have a 2.5 procomp lift with 31s. The ride is stiff with the new springs. But that's expected. If you do decide to replace them, use some sort of fire, propain torch is the way to go, and be sure to have a sawz' all with a few replacement blades. I did it the hard way using a hack saw, and a drill. Either way works just be smart about it.
    Go easy,
    KEN
    DANGIT it's not a bronco!
  5. sting
    Aug 14, 2000
    31
    OK..I know its not a caddy...its bone jarring... it has rancho 5000 shocks...are there better
    leaf springs that absorb pot holes and wash boards...if so what are they I dont care what they cost..
    Thanks for your reply....
  6. J.R.
    J.R. Guest
    look for the soft ride springs, contact off road design. they're a good company and really know there stuff!!
    BIG BLOCK MAN
    "MORE POWER"!!
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I hate to tell you this after you just bought shocks but Rancho 5000s are about the stiffest shocks made. If you want a better ride the Gabrial LT shocks with the VST valving are about the best for the money. I switched from Rancho 5000 to Gaberials on my K5 and like the Gabrials a lot better
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I agree. Start out by replacing the Rancho 5000's (I have them and they hurt my back). If you have the $$$ buy Bilstiens(sp?). They cost about 70 each. If you plan on ever lifting your truck do it now or you will end up rebuying shocks.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    To make your 84 ride better, FOR FREE, simply get some old inner tubes and cut them and tie one end off on them. Fill them up with sand and tie the other end off. Throw them in the back and you will have extra weight in there that will soften the ride!!! [​IMG] [​IMG] [​IMG]
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have the RS 5000s. If these are stiff shocks, wow. I always brag that my truck rides like a caddy, imagine what softer shocks would do!!!
    I have 4" Rancho soft ride springs. They ride very nice.
    Tim
  11. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Go back to the store that you bought the Rancho's from and see if you can exchange them for the 9000's (about $40 more per shock) but well worth the adustable shocks....If you have quad shocks up front only use one shock on each corner.....
    Put rubber bushings in if you want to soften the ride Poly's let you fill the road more due to the stiffness of them....replacing the stablizer bar bushing will help also.....
    Check your springs to make sure that they are Stock... and that thdey aren't worn out to the point that they are resting on the bumper stops......your have a rubber one in the middle of spring arch and you may have one in the rear of the spring that is a limiter for the spring.....If your riding against or close to them your ride will be shitty....
    C'moe
    Kill Roy was here!
