How can I make my Blazer stop easier
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chaka454, Mar 29, 2002.
  1. chaka454
    chaka454 1/2 ton status
    Nov 13, 2001
    199
    California
    I just finished replacing the axles in my Blazer and I put 35 with a 14 bolt so obviously the rig is alot heavier now, so now when I apply the brake it seems like it's never gonna stop, how can I get a little more stopping power, and I'm not talking about a 44 Magnum, I already got one of those thanks in advance.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Lighten the vehicle up /forums/images/icons/smile.gif It really helps getting rid of anything you dont need. The rear disc brake swap should help as well. If that doesnt work then its time for a dana 60. There rotors and calipers are huge!!
  3. Grim-Reaper
    7,385
    Atlanta
    I have 35's on the half ton gear and I'm not having much problem. You sure you got them bleeded completly> adjust the brakes in the rears up till you can feel them drag.
    Flush the brakes system and use Castrol Fluid GLX. It's DOT 4 spec. Cheap front pads don't cut it. Pep Girls sells Rayspestos Gold. Good pad. I can lock em down with 35's
  4. chaka454
    Nov 13, 2001
    199
    California
    Serious? hmmm than I'm going to see the girls and getting me some of those good pads and bleeding all my lines really good because I neen some good stopping power, thanks alot for the info
  5. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Also check to be certain you've adjusted the rear shoes correctly. Although self adjusting, it helps if you adjust them manually the first time to be certain that the shoes are as tight as they should be. I always adjusted mine until I could just feel a little drag. At least I did until I swapped for TSM discs. End of problem!
  6. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    look into the BIG 1 ton brakes.
  7. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    i got the big 14in brakes and it stops great with 36 inch tires, i just got to be careful and not lock up that rear, sometimes its real easy.
  8. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Stainless Steel Brakes also offers a big front brake kit for Chevys. I believe it comes with 12 1/2" vented rotors and 4 piston calipers. Last time I saw it was arond 400 bucks for the kit.
  9. chaka454
    Nov 13, 2001
    199
    California
    Hey 86 K5trailblazer where did you get your brakes from, got a part # or something, and would those brakes fit my 14 bolt 9.5"?
  10. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    Parachute? /forums/images/icons/smile.gif/forums/images/icons/shocked.gif
  11. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    I seen Herman Munster stop a dragster once just by grabbing the back of it!
  12. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    stand on the pedal a little harder
  13. 86K5TrailBlazer
    Apr 24, 2001
    436
    Orange,CA
    its stock from a one ton axle, your axle is smaller and had 10bolt size brakes, i would just go with discs in the back if i were you. and maybe dual piston calipers up front
  14. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    yeah, make sure the brakes are bled and the shoes adjusted properly...with my 14FF and drums I can lock up my 33's easily.
  15. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    I own 2 K5's...of which 1 is a 1976 Chalet...that used to stop like a Sherman tank...cure: bone yard shopping for CORE 85 -91 C/K 10 brake booster....and master....exchange at parts store...install...swap the lines front to rear...and tadaa...better stopping. Late model masters have a bigger bore and a quick take up valve...now both K5's are done and brake problems are a thing of the past.
    Azblazer
