How can I remove the big pinon bearing without damaging it??????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fad2blk99, Sep 26, 2003.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    How can I get the forward pinion bearing (the bearing up against the pinion gear) off without damaging it? I'm setting up my front axle, and I need to add more shims and increase pinion depth to try to get a somewhat more respectable pattern. /forums/images/graemlins/angryfire.gif
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    You need a bearing separator like this,
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    And a press /forums/images/graemlins/thumb.gif
  4. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    I got the press....
    Where can I get one of those.... /forums/images/graemlins/tongue.gif
  5. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Never mind....
    I found one...
    Harbor Freight, $19.99
    Thanks,
    You guys (and gals) are the best!!!!! /forums/images/graemlins/thumb.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I tried the largest one that my local Harbor Frieght store had in stock, when setting up a 10-bolt rear in my S-Jimmy. It wouldn't work. /forums/images/graemlins/angryfire.gif It just wasn't big enough and/or well enough made to slip under the bearing race. I ended up renting a Snap-On 5-inch wide bearing splitter from a local rental-all type of place for the day. The blades on it were machined down thin enough to slide under the bearing quite nicely. /forums/images/graemlins/cool.gif
    I would have just bought one of the Snap-On's but they're $133. /forums/images/graemlins/eek.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    What axle are you working on? Some axles don't use shims under the pinion bearing but rather under the race instead.
    I just looked at your profile and see your rig has a 10 bolt front. You may still install shims under the race if you need less pinion depth. My $.02
  8. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Yup, It is a 10 bolt front (converted to 8-lug). The original set-up had a shim under the bearing, so I reused the same shim under my new pinion bearing. I'm about to go pry out my carrier (for the 4th time /forums/images/graemlins/angryfire.gif) and try my new $20 Harbor Freight Bearing splitter. Hopefully I'll have better luck. I checked NAPA and they wanted 70 bucks for their splitter.
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I'm about to go pry out my carrier (for the 4th time /forums/images/graemlins/angryfire.gif )
    Now ya know why it ain't cheap to get new gears installed and set up. /forums/images/graemlins/wink.gif
  10. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
  11. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    I was able to get my Harbor Freight crap to work... I see what the other guy was talking about though. I was able to turn the tool upside down to keep it off the cage. The pinion gear on a 5.13 is pretty small, so it didn't hit the teeth. If I had to do this on a regular basis, I think I would opt for the one from Randy's R&P....
  12. seattlek5
    Feb 23, 2001
    311
    I do a lot of gears (work at a Jeep dealership, Grand Cherokees go through the factory bearings very quick /forums/images/graemlins/rolleyes.gif) With the blue puller I can strip all the bearings off the carrier and pinion in less than 5 minutes (could reuse them if they weren't pitted.) Then you only have to use the press to install them /forums/images/graemlins/thumb.gif
