How can i see the difference between a 305 and a 350
Discussion in 'The Garage' started by keevy, Apr 26, 2005.
  1. keevy
    keevy Registered Member
    Aug 24, 2003
    36
    Belgium
    How can a i see the difference between a 305 and a 350 moter.
    Thanks :blush:
  2. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Block numbers are pretty much the only way... though somehow my mechanics knew I had a 327 just by looking at the block without seeing the numbers... of course I hinted that it might be a 327 to begin with, but they were right. My 327 was a 69 block, but isn't worth the metal used to build it...
  3. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    the best and only true way to tell is the casting # on the driver side rear of block on top of bellhousing lip. run it or post it up and we can do it for ya.
  4. dyeager535
    26,979
    or Suffix code, which is on the passenger side deck of the engine block, just forward of where the head meets the block. Behind the alternator.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    how was the 69 327 not worth anything ?
    :O
    and yeah go with stamping code it will tell you not only size but year, model, tranny, hp and torque and mains and carb usually
    front stamp pad last two or three letters of it capitalized
    post here or whatever and one of us will decode it for you if you cant
