How can I tell if I have a mechanical stock oil gauge?
Discussion in 'The Garage' started by wazzabie, Aug 7, 2005.
  1. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    1978 K5 Blazer
    I would like to get a tach off ebay and install. Hope to do just a bolt in with the cluster.
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    look for the line running to the oil pressure sender,,, it has fluid and not electricity flowing thru it :D
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Do you have a copper looking hardline from the back of the engine to the gauge ?
    I have a 77 body that had one .
    I don't know about 78 , as the 78 Sub in the back yard HAD a tach dash and a sender with a wire on it for oil .
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    there is also a peg visible on the guage face that acts as a zero stop, if no peg, then electric guage
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    most all 78-up were electric, but who knows whats in it now,
    just look behind distributor to see if theres a tube or a wire plugged on
  6. wazzabie
    Apr 17, 2001
    1,719
    5
    Washington State
    It is electric. How hard is it to change to mechanical? What are the advantages/ disadvantages of using the mechanical?
  7. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    It isn't hard. All you have to do is run the hard line. Electric gauges have more of a tendancy to shoot craps. The only thing with a mechanical gauge is if the supply line breaks in the cab.
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    To change to mechanical, all you need to do is get a mechanical gauge and swap the sensor to a mechanical sensor/fitting. Pretty easy....
    Only drawback that I see is the oil line running to the cab... Mine liked to leak a little here and there.
