how can i tell if my 14b is a sf or ff? thanks for the help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by skyyk5, Jan 16, 2007.
  1. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    i have a hd44 and 14b under a 79 3/4 ton that i haven't got the ambishion to tare off yet. is there an easy way to tell if its a full floater or semi float axel.
  2. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    GM CORPORATE 14-BOLT Full Floater
    With a 10 1/2-inch-diameter ring gear, the biggest 14-bolt GM rearend looks much like a Dana 70, and is but a few thousandths of an inch shorter in ring gear diameter. This axle is commonly used with big engines and/or overly large tires and is 8 lug. It was used under 1973-87 3/4-tons.
    http://coloradok5.com/axleguide.shtml
  3. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    take off the hubcap, in the center of the wheel, if you have bolts, it is a FF, if no bolts it is a SF
  4. fendereff
    fendereff 1/2 ton status
    Jun 24, 2005
    207
    Aggieland, Texas
    on a full floater, the weight of the vehicle sits on the axle housing, so the axle housing will stick thru the center of the rim. on the semi floater, the weight is on the studs and the axle shafts. and look at the rear diff. a ff is like the pic above. a sf is just round.
  5. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    Full floater looks like this, minus the little cap. Semi is like a car, just a cup in the casting. Look at ANY dually, they're ALL FF and usually don't have a hubcap, so easy to see...
  6. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    thats what i though just never really looked into it. killer i got a nice ff for the k5! thanks everyone.
