how can i......
Discussion in 'The Garage' started by NEK5, Jul 26, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    make sure that all my motor needs is valve seals??? i know she`s burning oil.......just want to be self assured thats my only problem
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    if it only smokes on startup and a few minutes afterwards your cool...if it keeps smoking you have issues
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    it does continue to smoke as well, particularly when in 3-4000 rpms, for instance, if i punch it a little a look in the mirrors i can see a little smoke, and the other day while driving around, i shifted into one or L, and it would smoke when i went into higher rpms, and you can smell it too, sometimes bad, and one time my mom drove behind me and said my truck smelt
  4. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    u need a rebuild dont feel bad im in te same boat fixing to yank her out, my number seven shoots oil out the cylinder
  5. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Or the 350 I have that he never got back to me about. :rolleyes:
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Why don't you do a leakdown before you settle on a rebuild?
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i dont know how its done, and if i`ll even be able to do it
    the problem is i wouldn`t even be able to put it in
  8. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    I am currently expieriancing the same problem with my 350. I am in total agreeance with you. I am counting on doing some head work soon. Would be a good time to go Aluminum I would think.
  9. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i would love too, the problem is, i have no way of doin the work
  10. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    so, do the problems i`m having most likely have something to do with the heads?
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ttt.... i had someone tell me that it could be my pistons/rings??? is there anyway to make sure, if its the heads then i may look at purchasing some new/rebuilt ones....if not then i dont know what to do.....
  12. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    X2 Or at least a compression check.
  13. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    i dont want to sound negitive but IMO fixin something like valve seals to fix the smokeing issue is kinda like puttin a bandaid on a severed arm. if your engine smokes its time to rebuild period. youll just run into more problems sooner fixing 1 thing at a time on an engine. i know it cost more and takes longer but its worth it. also a tip for low budget guys is take advantage of automotive schools if there is one local. i had mine rebuild by the local automotive school and the long block only cost me $560 including machine work. and most any school will take pride and do quality work. the teachers are almost always right there and sometimes hands on. the teacher here has several degrees in automotive and all the ASE certifications so im not worried about it being done right although it took longer (about 3 months) but i had planed ahead so it wasnt an issue
    balzer
  14. MarcS
    Oct 4, 2002
    515
    NJ
    If it smokes on start up only, valve seals are easier and cheaper to replace than a rebuild.
    I can understand the logic if it's something worst.
  15. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    will one of those tests tell me if its either the pistons/rings, or the heads?
  16. MarcS
    Oct 4, 2002
    515
    NJ
    Not really. Just verifys if the combustion chamber is leaking or not.
    What 79k20350 said-If it smokes on start up, then clears up, it's probally just the valve seals. It will cause oil loss over time.
    If it's smoking all the time, and the oil levels going down alot, then it's probally the rings.
    Valves themselves not seating properly in the head will cause a leak, but shouldn't burn oil.
    Comparing the pressure cylinder to cylinder during a compression check will detect bad head gaskets.
  17. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    could the seals be so bad that its constantly letting oil blow by?
  18. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,836
    8
    Grand Junction, Crawlorado
    My 350 as well is in need of some repair before it gets worse. I have a good power loss and some smoke So as soon as money allows Heads off and down to the Machine shop. Is it a good Idea to find some heads in a Junk yard and just go have tem work over then swap mine and do them when I have time and money? Then hold the extra set.
  19. MarcS
    Oct 4, 2002
    515
    NJ
    The oils not going to blow by. There is no real pressure. It just sits on top of the valves under the valve covers and leaks by the valve seals when the engine is off. Thats why it smokes then clears up after you start up and run a few minuites. The leak is slow, so when the engine is running, it's hard to say if the seals are the problem compaired to the rings.
    Your going to burn alot more oil with bad rings then with bad valve seals.
    The valve seals are cheap and easy to replace or use whats called umbrella seals to fix the problem.
    Rings, :frown1: ---Time to rebuild/replace engine.
    Does the engine smoke on start up and clears or does it smoke all the time ??? That will give you the answer to whats next ??? Let us know.
  20. MarcS
    Oct 4, 2002
    515
    NJ
    Be careful putting money into the top end of the engine and not doing something about the bottom. Your better off saving money and doing a complete rebuild instead of band-aiding it.
