How can you tell?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nyyef, Aug 17, 2000.
  1. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    i have someone that is going to give me a 12 bolt cheap!! but i dont want to have a piece of junk lying around in my house.
    just by pulling the cover and inspecting the inside, other than the wear pattern on the gears, how can you tell by looking at it if it is ok? (without installing it and driving around).
    thanx
    Knife.
    knife.coloradok5.com
  2. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    Try grabbing stuff and seeing if it wiggles/moves in the obvious wrong directions.For example...the ring gear and carrier,shouldn't move either side to side or in and out.
    (round and round is a good thing though)[​IMG].See if the outer ends of the axles move alot when you wiggle them side to side/up and down.These might point towards it needing a rebuild.A LOOSE CABOOSE IS A BAD THING!
