How close am I to passing?
Discussion in 'The Garage' started by johnnyclueless, Mar 2, 2005.
  1. johnnyclueless
    johnnyclueless Registered Member
    Nov 26, 2004
    51
    Well I just took my 78 in for the dreaded arizona emmission test and I failed. I wonder based on the number below how close I was to passing - whether I just need to adjust the carb.
    Hydrocarbons Loaded Loaded Result Idle Idle Result
    Reading Standard Reading Standard
    182 350 Pass 391 350 Fail
    Carbon Monoxide 4.48 3.00 Fail 7.80 4.00 Fail
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I just scored a 78 tub , did you need cats , I heard no cats on 78 ?
    Tune up is a good start . What have you done to it beforehand ?
  3. johnnyclueless
    Nov 26, 2004
    51
    I've done quite a few mods since I ran it through last year. I added headers, new dual exhaust, new distributor - I definately have messed with the carb and I have the timing advanced about 6 or 8 degress so I'm thinking it might be as simple as that. I have no cats on it. It passed the visual.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well a good tune up and reset the timing will probably help . Don't forget to drive for awhile to heat the motor up . Also , did you change the oil ? You need to prior to running for insurance :k5: :k5:
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Retard your timing.
