How cold is tooo cold?
Discussion in '1982-Present GM Diesel' started by Pookster, Jul 31, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I remember last year in vermont, went skiing- Nighttime temperatures easily dropped below -25F.
    is it ok to drive a diesel in those conditions? Good charged batteries, good glow plugs, and also a lot of additive- they claim to offer anti gel capability down to -40.
    Just thought I might check with you guys.
  2. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    plug in yer block heater /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Watch it with the additives, don't go overboard, you'll be shooting flames through your exhaust or worse exploding your engine.
    They have a recomended amount, you could probably raise it a 5% no more.
    As for the temps, if you are still mixing fuel and WVO I would use #1 not #2 when I mix, which is straight Kerosene if I am not mistaken or more kerosene at least.
    If you have the option, plugging in the block heater helps, but if you are like where I go out in the snow in the middle of nowhere your only bet is the good additives and good glowplug system with new batteries and a good starter.
    /forums/images/graemlins/peace.gif
  4. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Where do I plug in a block heater while at the ski resort? /forums/images/graemlins/dunno.gif
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    strangely enough, they dont have a maxiumum amount- and it seems as if extra additive doesnt hurt anything. (The PowerService stuff and the DFA).
    In regards to the vegetable oil- no I will not be running a mix in the winter- the gelling point is just too high, i dont think i'd be able to acutally get the stuff to move.
  6. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    It can be done safely.
    1. 1000 CCA Batteries + Perfect battery cables.
    2. 5w40 Rotella (Don't forget to change this when the weather warms up)
    3. Manual Glow Plug controller w/ Kennedydiesel.com Quick heats, hold them on for 30 seconds.
    4. Plenty of fuel additive maybe #1 with additive.
    My 99 starts in -15 weather no problem without pluggin in.
  7. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    I would add the gear reduction starter to that list. Mine starts 100% better in the sub zeros since that swap and the batteries don't take as much drain befor it fires.
  8. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    In temps that cold, I leave the KW running all night, even with the fuel additive,UT/WYO temps in winter are sometimes even colder then that. I wouldn't trust the smaller deisels to start in those temps either, it's the only way to make sure that it runs /forums/images/graemlins/thinking.gif /forums/images/graemlins/waytogo.gif
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I use the power service stuff too, and I have seen flame shoot out my exhaust when I went with double the recommendation.
    I talked to a couple of diesel mechanics I know that work on fleets of trucks and they say that have seen that happen, so I figure why push it, the additive is supposed to be good for the temps I am running so I just go with a 10% over to make sure I got the right amount but no more 200% for me, it scared me when it happened twice on my way to Lake Tahoe.
    /forums/images/graemlins/weld.gif
