How could i...
Discussion in 'The Garage' started by Confedneck79K30, Nov 23, 2006.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    break a dana 50? i was at a shop yesterday and someone had broken the pinion shaft, inside the housing, in TWO places... and on 35" bfg a/ts at that... i was just wondering what kind of abuse it would take, that pinion shaft is about 1" to 1 1/8" thick...
    i was figuring, hooked to somethin heavy and lettin it eat and hop??
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    did the truck have a snow plow on it? I have seen some particularly idiotic individuals do some downright retarded stuff to an otherwise nice truck with a plow on it.
  3. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    negative, not much call for snowplows in florida...
  4. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    what kind of truck was it under? if it was a ford.. there's ur answer :haha:
  5. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    well hence the dana 50 part lol... i was just wondering how a pinion shaft breaks.. i mean it only had a 5.4 anyways..
  6. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Oh, I haven't been to Checked Out, Fl. Just the beach:D
  7. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    LOL i forgot i changed that doh...
  8. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Well, despite having a 9" ring gear and a correspondingly decent sized pinion gear the pinion shaft is pretty small in the D50. According to the specs, it is 1.375" in diameter. By comparison the D44 has a 1.437" shaft, and the 10b and D60 have 1.625" shafts. Pinion shafts have a LOT of load on them: both torsional and bending loads. Usually the smaller shaft allows the pinion to deflect away from the ring gear, and the high loads move toward the top of the gear teeth. This usually results in gear tooth failure. However, it is possible that the weenie shaft on the D50 might fail before the teeth. Either that, or it had a flaw of some kind.. although some could argue that a 1.375" pinion shaft in 9" ring geared 30 spline diff is a flaw of the design variety :whistle:
  9. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    I'd be willing to bet he got it airborn, and came down under full throttle. When someone does that, unless the ground is verrrry loose/soft, it puts a tremendous strain on the pinion shaft and teeth; sometimes even shattering the pinion gear.
    Jimbo
  10. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    's what i thought.. thanks guys for helping me expand my knowledge
  11. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    back to the 10b vs. d44, isnt that grounds to say that a 10b is stronger?
