How could this happen?
Discussion in 'The Garage' started by 88trailblazer, Nov 22, 2005.
  1. 88trailblazer
    88trailblazer 1/2 ton status
    Apr 11, 2004
    425
    Miami, Florida
    I noticed this the today while under the truck. What could be causing the overspray on the exhaust pipes? I have not seen any leaks on the driveway (at least not from that part of the truck). Could the u-joint have crapped out?
  2. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Looks like the seal on the rear output (tailshaft)
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    it might just be leaking a little when your moving (the shaft is spinning) so it doesnt happen when its still.
  4. 88trailblazer
    Apr 11, 2004
    425
    Miami, Florida
    thanks for the help. Do you think its really worth worrying about?
  5. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    could also be extra grease from when you lube the ujoint.looks like there is grease spots on the bottom of the floor.
  6. 88trailblazer
    Apr 11, 2004
    425
    Miami, Florida
    thats also what i was thinking. Tommorrow i'll change out that u-joint just to be safe
  7. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Its just fluid from the output on the trans. I wouldnt worry about it, its not something thats in dire need of replacement...
