How did you change to inboard /\ rear shock setup?
Discussion in 'The Garage' started by DougK20, Dec 27, 2003.
  1. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    How did you change to inboard /\\ rear shock setup?
    I will be doing this today and was looking for ideas. What worked for you? What didn't?
    Thought: Has anybody thought of a way to use a bolt-on axle mount. Possibly through your u-bolts?
    I just installed ORD shackle flip and now have way more flex than my current shock locations can handle! Pics, if you've got'em. Thanks!
    New shackle flip, yeah!!!! No more blocks! (I will wait to trim the u-bolts until I get some zero-rates in there.) /forums/images/graemlins/thumb.gif
  2. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Re: How did you change to inboard /\\ rear shock setup?
    I think I would consider adding some bump stops. Those springs might not last long flexing into the negative. Can't help you with the inboard shocks. I have yet to do this but I will follow this thread for some tips. Good luck.
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Mo-offroad has a bolt on kit that uses collars around the axle tube to accomplish a simple bolt on conversion.
    mo-offroad kit
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    bed floors are highly overrated.
  5. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I've always liked that setup. I may still that design when I am no longer in need of a rear seat!
  6. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    I have the mo-offroad kit, real easy to install and seems like it is gonna work great /forums/images/graemlins/thumb.gif If you want pics let me know !
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    got mine from 55willys. dont think he makes them anymore, but he might. They came with the hardware to attach each side of the xmember with 4 bolts, but I only used 2 bolts in each end and shane74 welded them on as well... has held up fine.
    x-member pic
    hope it helps,
    j
  8. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Had them like that. Now they r not. Do a search lots of info out there. As for me that was prolly 1 of the worst mods I had done. You can almost get the same effect by removing your shocks...The more you angle the less effective they become.
  9. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    let me try to explain my drawing..
    the black line is the spring plate, the blue lines are u-bolts..
    the purple is the bracing for the bracket (red line)
    the orange line is a ball-socket style bolt that rotates freely, like a heim joint perhaps
    the red shape with the green box is just a view of what the bracket with the ball socket bolt could look like..
    you could even use a small heim joint i guess or a regular bolt if you wanted..
    my only thing is that the ball-socket style bolt or heim joint might move too much, reducing the shocks effectiveness.. however, i figure if you used the regular bolt (orange line on drawing), only angled down at around a 45 from where it is now, you could run the shocks at an angle up under the tub/bed...
    does it make sense to anyone else?? should i just delete this rambling? oh.. and i guess it could be made to bolt ontop of the spring plate, between the springs and plate, or welded onto the spring plate between the ubolts..
  10. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    You could double them up if you find there isn't enough damping due to angle. Or if you have adjustables you could crank em up.
  11. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    THis is what i did. Cut the old shock hangers off turned them around then welded them back on. THen again my axle is 6" back from stock. I used an existing x-member. Oh, this is a blazer frame.
  12. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    mine /forums/images/graemlins/thumb.gif
  13. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Hey Zakk, is that crime scene tape across the back? /forums/images/graemlins/thinking.gif /forums/images/graemlins/thumb.gif
  14. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I made my own brakets... I cut my old brakets off the axle tube, modified them and welded them to the top of the axle (mounted so that when the bolt is inserted to hold the shock it runs front to back). Then I took a piece of L-angle steel bolted it to the frame. I drilled a couple hole in the steel and used the old upper shock mount hardware to attach the shock to it. It was a piece of cake!
    I wish I had pics to show you, but my digital went swimming a while back and Santa forgot to bring me a mew one this year.... /forums/images/graemlins/frown.gif
  15. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I plan on doing the Missouri Offroad setup with the over the top axle truss on my Corp14ff which incorporates lower shock mounts on the outer clamps and the upper mounts inboard, but at their farthest outboard setting and using their inboard upper mount. I talked to MOO and he said I could order the axle truss set up for a traction bar that I could install later. Pics here: http://www.mo-offroad.com/whatsnew.htm
  16. DougK20
    Feb 18, 2003
    384
    Boise, ID
    Thanks guys! I am almost finished my brackets. It will end up looking alot like Jekbrown's setup. Though, I LOVE the extended shocks through the bed! Maybe someday...
    If I find it does not dampen well enough I can easily double up the shocks. Though it is a pickup and the rear is very light. Thanks again! /forums/images/graemlins/thumb.gif
