How did you get your 38872 brake hoses to work?
Discussion in 'The Garage' started by y5mgisi, Mar 25, 2004.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I just went and picked up the 38872 brake hoses from napa and it dosnt look like the line will hook up at the caliper.
    And for the record i have a 90 suburban with 10 bolt front. What did you guys do to make it work adn work right? /forums/images/graemlins/ears.gif
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Mine boltedright up to my 10b from an 82 /forums/images/graemlins/dunno.gif
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    the part that bolts up to the caliper is it square???
    justin /forums/images/graemlins/burb.gif
  4. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
  5. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    Ya
    my extened lines are like that too and the mounting point on the caliper is round /forums/images/graemlins/confused.gif that's why I haven't installed them yet but I think I might take it to an bench grinder to sole that problem....
  6. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    yep i think im going to go ahead and do that too. /forums/images/graemlins/hack.gif
  7. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    that always solves the problem........
    justin
  8. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    my extened lines are like that too and the mounting point on the caliper is round that's why I haven't installed them yet but I think I might take it to an bench grinder to sole that problem....
    I installed pro comp ss lines on my 3/4 ton 10 bolt and had to trim the corners of the brake line mounting tab to fit inside the caliper mounting well. I trimmed the corners with a band saw and finished the rest with a file. You can use the washer as a guide. /forums/images/graemlins/thumb.gif
  9. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    cool I'm going to install them this weekend...
    thanks
  10. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Good luck /forums/images/graemlins/thumb.gif
  11. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    well yesterday I put on the extened brake lines... I used an bench grinder to round off the mounting point, worked out really well. also had my dads friend bleed the brake system. the brakes never felt better /forums/images/graemlins/smile.gif
