How did you mount your Windstar fans??
Discussion in 'The Garage' started by 90blzr, Feb 9, 2005.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Got a fan set up from a 98 windstar the other day. Can you guys who have done it, tell me or show pics of how you mounted it to the radiator? My radiator is the 34x19 size so there is some space around it.
    Also need to know how to wire it up. I suck when it comes to relays, etc.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    A couple AZ guys have done it , I saw it on weisel's truck a couple weeks ago . Maybe one of them will see and post up :D
  3. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Also try a search on winstar fans. There are quite a few pics floating around here too :grin:
  4. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    look in the tech section for the writeup on the windstar fan install;)
  5. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
  6. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Wiring diagram looks good, BUT, all the colors look almost the same. I guess this monitor is f'd up!!!!!:mad: The yellow is about the only one I can tell. ****.
    I dont know what the hell my radiator is from. All the ones I have seen or have talked to people about they say the shroud fit just about perfect. My radiator measures 34x19 and I have a few inches all the way around!!!!:mad:
    So it looks like I'll need (3) 30amp breakers, 4 relays (what size?), 3 switches, and a temp sender.
    Also what size wire should be used?
    In the diagram the wire going from the temp sender to the 'high speed enable relay' is that ground?
    Also on the diagram the wire from the temp sender to the high speed relay it is spliced into the wire coming from the control relays....is there a 'clean' way to splice those four ends together?
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    there is red, green and yellow wires. The darkest ones are red, the lightest ones are yellow, and green are the middle colored ones. Hope tat helps.
