how difficult to install 2wd steering box
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990K5, Dec 14, 2001.
  1. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    and... what is the best (latest model) donor vehichle? thx j.c.
  2. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    annyone??
  3. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I wouldnt mind hearing also.
    Sorry I couldnt help. Havent done this myself yet, yet.
    Ken H.
    '86 K5 up and coming
    14 bolt(Detroited),10 bolt
    44 TSLs
    468 BBC, 350 trans, 205 transfer
    Rust free in Michigan!
  4. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    well your 90 is plenty new
    for us old truck owners we are generally stuck, unless we are going aftermarket, with a vintage similar to what we own.
    the input shaft on the box differs.
    from what I have seen all the boxes are equal.
    if you are a part books god and can learn to mix n match steering internals anything is possible, a la AGR in the old days.
    safest bet is to get one from a similar vintage to ensure the hydraulic fittings and input gear are compatible
  5. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    would a 91 2wd sub box bolt up?
  6. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Just swap the output shaft. It is extemely easy. I installed a 2wd shaft in my '89 box with the box still in the truck. Be sure to adjust the backlash and replace the output seal though.
    thebigdaddyof2
  7. michaelm
    Feb 2, 2001
    872
    physically bolt to the frame? any box from 1973-199? when they discontinued the body style will bolt to the frame and could be made to work.
    the details is where the fun begins. meaning hydraulic fittings and steering wheel input shaft variations must be looked into
    1991? I would assume so, but someone else would have to answer as my junk is 1977 so I never looked that new.
