How difficult to re-cover stock seats
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dbozman, Jan 22, 2007.
  1. dbozman
    dbozman 1/2 ton status
    Nov 11, 2006
    115
    Phoenix
    The seats in my '74 are shot, but the frames are good and the foam is OK. I like the look and feel of the stock seats and would rather use them than aftermarket.
    I was looking at this "custom-fit" set for a little over $300:
    http://www.1aauto.com/1A/SeatUpholst...SU00035/148623
    Anyone ever done this? How difficult to do it correctly? Thanks.
    d
  2. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,236
    284
    San Jose, California
    I'm 2/3rds of the way through (did rear seat + passenger) and it's not too bad. I used covers from a different place though, but they look the same.
    1. Trash the hog-ring pliers they give you and use some normal pliers. Those things suck and I ended up wasting half the rings because the pliers would bend them the wrong way. (Maybe I just got the cheap version from LMC). I ended up using zip-ties instead of hog rings on the interior after I ran out and the zip ties were much less frustrating and worked fine.
    2. Also make sure not to throw away or break any of the wire in the existing east covers since you re-use those.
    3. Since you're keeping your foams this may not affect you, but my foams were molded onto the frame so I had to tear them off in chunks instead of a single piece. That was a day long process in itself.
  3. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    it's easy did mine in three hours. i used the hog-rings though without a problem. i got mine from a place called - fryer's upholstery- phone #1-360-652-4794 they were very helpfull.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
