how do heat shields work?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tweaker, May 21, 2004.
  1. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    i have a 1988 chevy, i'm swaping the t-case to a np205 and changing the exhaust to go out the driver side instead of the passangers. here's the problem. the fuel lines run down the frame on the drivers side and the fuel filter will be less than a foot away from the catylitic converter. so i was thinking of doing one heat shield on the frame rail and then another a few inches away and not connected, but will this work?
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Any time you can create an air space (especially moving air) your doing better since only radiant heat can travel (or close enough). My guess is the double shield would work well enough...
  3. tweaker
    Mar 21, 2004
    263
    thanks, i wanted confirmation that it should work. the tbi is bad enough with out having vapor lock due to heat too close to the fuel line.
