how do i adjust my valves?
Discussion in 'The Garage' started by bigoltrux77, Aug 13, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    i have a 7 blazer with 350ci engine. I need to adjust my valves bc the are hitting the covers and it is really annoying. Can someone tell me how to adjust them, what tools ill need, and how hard it is? thanks alot
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I don't think adjusting your valves will solve a rocker hitting problem.
    Are these stock rockers/springs?
    If you are getting a valve lash tap... then adjustment is necessary.
    ***Assuming this is a hydraulic flat tappet cam/lifter.
    You WILL GET OIL EVERYEHWERE!!! Even if you use the rocker clips... /forums/images/icons/crazy.gif
    With the engine idling... turn the rocker loose until it taps loudly (assuming it is not doing this already). Turn it tight until it stops tapping.. Now turn it (some say 1/4) 1/2 turn (per HAYNES manual) tighter. That one is done. Only 15 more to go.
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    LAy something under your truck..... i didnt, and got oil all over the driveway,
  4. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    You don't need to get oil everywhere. Here's what you do:
    Get an old set of valve covers and cut the top out of them so you can have access to the nuts. Mount them in place and there you have it. Do your adjusting, then replace with your good valve covers.
  5. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    heh right on, i wish i woulda thought about that,
  6. lugnut
    lugnut 1/2 ton status
    Aug 3, 2001
    268
    North Carolina
    Thats a great idea!!!!!! I'll try it next time I adjust valves.
  7. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    probably doesn't work with centerbolt valve covers though...
