HOW do I adjust the kickdown cable properly?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Dec 27, 2002.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Just picked up a complete tranny from a rebuilder in my area today. The guy there was telling me how critical the adjustment of the kickdown cable to the tranny was. He said it has to be done right, or else the tranny wont shift properly. How do I go about making sure the cable is adjusted properly?
  2. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    I assume that you are referring to a 700R4 trans.....
    For a basic explanation, this should be set-up to pull the kickdown cable tight at full throttle. There are considerably more elaborate procedures, but this is the fastest, easiest method. If set too loose, it will lessen line pressure & can cause premature failure due to slippage. A good test for proper tension is that the tranny will make a full throttle downshift to 1st from a higher gear during a slow speed coast. (approx 20mph depending on rear gear ratios) Hope this helps.
    Lonnie Pavtis
    Lonnies Performance Automotive
  3. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Appreciate it... yes, I am refering to a 700R4 for an '89. Any other suggestions?
  4. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    if you pop off the pan and someone presses on the gas pedal(engine off) while your looking at it from the buttom of the transmission, if the kickdown cable ingages all the way is it properly set?. I didnt quiet understand the last post /forums/images/graemlins/confused.gif
  5. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Anyone know of a resource that might cover a more elaborate procedure?
  6. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
  7. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Sweet.. thanks a bunch.
  8. Stylzz
    Stylzz Registered Member
    Sep 9, 2002
    95
    Mystic, CT
    I think the Haynes manual explains it. If its like my 350, set it at full throtle and adjust from there to your liking. You just need to drive around the block a few times with a little screwdriver.
  9. TennesseeJ
    TennesseeJ Newbie
    Dec 30, 2002
    Memphis Tn
    Hello, I am new here. I just bought a 85 K-5 and was checking out the site when I ran across this post. The TV cable is totally different than a turbo 350 kick down cable. It not only controls kick downs, but very critical line pressure. You can learn how to adjust it properly from here: TV cable adjustment . Although this shows it on a TPI Trans Am, adjustment of all 700r4 cables is the same. I look forward to learning alot about my new toy from all of you. /forums/images/graemlins/grin.gif
  10. blzn1
    blzn1 Registered Member
    Apr 9, 2002
    76
    SO-CAL
    what about us peeps who have the 350 tranny. Is it the same
    way?
  11. BigRed89
    Oct 28, 2002
    223
    Los Angeles, CA
    The TH-350 transmission does not have a TV cable like the TH-700R4, so you don't have to worry about it. The TH-350 controls kickdown via engine vacuum.
