How do I build a homemade tire groover?
Discussion in 'The Garage' started by OffRoad, May 16, 2005.
  1. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    I have some tires the need chunks taken out. I tried useing a torch and knife, but that takes too long. I was going to try grabbing the knobs with pliers and cutting them off with a big soldering iron. Is there anything else that might work?
  2. jmd4x4
    jmd4x4 1/2 ton status
    Apr 4, 2005
    137
    Rosenberg TX
    You could always use a 4in grinder, it just make a lot of smoke. :D
    later
    jmd
  3. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    thats a good question, im quorious to know too.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've seen a circ saw with worn out Dado used. Set your depth and go, but you are basically stuck with straight cuts and very few options.
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I thought there was something that could be done with a welder and a jigsaw blade..
    But, there is always this too... it's not too much.
    Tire Groover
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Come up to my chilly state. We have a club groover that we can rent for $5 per set of tires. :D
    Seriously though, it sounds like you're trying to remove tread blocks rather than just groove them. If that's the case, I've seen someone (note: I don't recommend this and wouldn't try it on my tires) grind down the teeth on a sawzall blade and just come at it from the side. The bad part about that is if you slip and things don't go your way, the blade could puncture the tire.
  7. OffRoad
    Dec 8, 2002
    852
    i thought about using a 260 watt soldering iron. i can buy a new wire part and weld a piece of exacto blade to the end. when the wire heats up it'll heat up the exacto blade and cut my tire.
    the "hot knife and torch" thing worked really well. it's just super slow and uses lots of fuel.
  8. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    the grover works great. and you can get heads up to 1/4 wide. with square and round blades. i did 42" swampers like all the rock crawlers do in about 30 min a tire with mine.
  9. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    They make a chainsaw blade/4" grinder attatchment. I have seen alot of the local log home guys use it. It cuts tire lugs scarry fast!!! I tried it on a set of junk tires and was too chicken to put it to my 44's. I ended up using a grinding wheel on a 4" grinder. It made a horable mess but worked. Next time I'll just buy a cheep grover.
  10. OffRoad
    Dec 8, 2002
    852
    where can i buy a cheaper groover in canada?
  11. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    online :)
  12. jeepman 8360
    jeepman 8360 Newbie
    Apr 16, 2007
    Nova Scotia canada
    yeah it's hard to find different stuff like that in Canada
    I was having a hard time finding something so I tried a router, you can set the depth and go to town. I used a 1/4" endmill but I just bought a 1/2" straight router bit and I'm going to try that I'll let you know
  13. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Use a chain saw:doah::eek1::haha:
  14. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
