How do I change where my TH350 shifts?
Discussion in 'The Garage' started by Topdown, May 19, 2003.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Title pretty much says it all... Where/how do I change the shift points on my TH350? I am shifting right as I enter my power range and its pissing me off /forums/images/graemlins/angryfire.gif
    /forums/images/graemlins/1zhelp.gif
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    unplug the vacuum line from the modulator on the tranny and use a small flathead screwdriver and turn the little screw inside where the vacuum hose hooks to the modulator i believe you turn it clockwise to make it shift latter keep doing this till it shifts where you want it to /forums/images/graemlins/thumb.gif
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    That only works if you have an adjustable modulator installed. Factory modulators do not have this feature. /forums/images/graemlins/thumb.gif
    To change the shift points, you can install a governor recalibration kit as well as an adjustable modulator. These two will allow you to change the shift points a few 100 rpm and a couple miles per hour. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    You can always install a manual valvebody and shift it yourself. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    well i was just assuming it has been rebuilt with a new modulator installed
