How do I check fluid level in transfer case.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89K5mudder, Jun 20, 2003.
  1. 89K5mudder
    89K5mudder Registered Member
    Apr 18, 2003
    20
    Random Lake, Wisconsin (Near Sheboygan)
    I have a 89 blazer and the transfer case is leaking a little. How do i check the fluid level in my transfer case and possibly add more.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    is that a 208 or a 241?
  3. 89K5mudder
    Apr 18, 2003
    20
    I think it is the 208
  4. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    Transfer case fluid is easy.
    Truck should be parked on level groung to check fluid.
    Locate the two plugs on the rear of the transfer case.
    The top plug is for filling / checking the level.
    The bottom is for draining the fluid.
    Remove the top plug and check for fluid at the hole. If it's full, you should be able to feel it at the bottom edge of the plug hole.
    If you don't feel any, add fluid (good Dextron ATF) until it starts to dribble back out of the hole. Replace the plug, and you're done! /forums/images/graemlins/thumb.gif
    Where's it leaking from? /forums/images/graemlins/confused.gif
    Byron
  5. cjblais
    cjblais Registered Member
    May 8, 2003
    25
    New Hampshire
    If its an 89 it should be a 241
  6. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    I agree on that it's probably a 241. The process for checking/filling is the same that SCJimmy described.
  7. mxrcr589
    mxrcr589 1/2 ton status
    Apr 17, 2003
    148
    poop
    what do you mean by replace the plug, you have to get a new one????
  8. Polaris
    May 30, 2002
    1,182
    No, you don't need a new one.
  9. SCJimmy
    Mar 7, 2003
    406
    Yeah, just meant "re-install the plug" /forums/images/graemlins/grin.gif
    Byron
