how do i check my gears???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by XHitman396, Nov 18, 2002.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    i was plannin on changin my tire size, but i need to know what gears im runnin, i gotta stock 87 blazer with the 700r4, 208 and the 350, plannin on runnin 35, but maybe 33's. any help appreciated...
  2. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    If you have the sticker in your glove compartment still that shows the RPO codes it'll be easier to find out. Do a search. There was a post with the codes just a few days ago.
    If you don't have the sticker then you can either lift one tire off the gound and rotate the tire one full revolution and count how many times the driveshaft turns when in neutral or pull the diff cover and look for the stamp inside.
  3. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    On older trucks like ours lots of stuff could have been changed by previous owners so I wouldn't trust the glovebox sticker too much. Better check physically using one of the methods mentioned in the post above this one. /forums/images/graemlins/wink.gif
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I always recommend to remove the diff cover and look for the gear ratio stamped on the ring gear. It's a good opportunity to check the condition of the internals and put new gear oil in.
    -- Mike
  5. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    I did the tire turning method, but I did not get the same results. So I marked the ring gear with some chalk. Then turned the pinion till the ring gear made one full revolution.
    If you just bought your truck or have had it for a while it is always good to pull the diff cover.
  6. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    No need to mark the ring gear (assuming its stock). The tooth count is stamped in it. A 3.73 will have 41 11 stamped before the date code. if you divide 41 by 11 you get 3.72727272
