How do I clean my rear end?
Discussion in 'The Garage' started by divorced, Jul 25, 2005.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    When changing rear end oil sometimes the stuff that comes out isn't very pretty and it seems like when I add new oil it will pick up the dirt/junk/metal particles that is still clinging to the walls of the housing, the carrier and gears, and the hub bearings, then my new oil will be dirty again.
    Is there any way to clean these? Can I spray some brake parts cleaner in there without hurting anything?
    :crazy:
  2. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Yes, brake cleaner is fine. Empty a 1/2 or a whole can in there then let it dry.
  3. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    another question about this... what about the magnet in some axles. do you just wipe of the junk that gets on that?
  4. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    toilet paper for most days, baby wipes for the beer sh...t days
  5. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I bought a brake cleaner sprayer from Harbor freight, and buy brake cleaner by the gallon, just pour in the brake cleaner and pressurize it with compressed air, it works really well and it will save you money.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    toilet paper initially, then soap and water later. :D
  7. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    now see, i was gonna post "toilet paper" but it's been done twice. i guess i'm still posting "toilet paper".
    oh and "soap" when i'm in the shower. :D
  8. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Cleaning rear DIFFERENTIALS
    I soak up as much of the oil from the bottom of the case with rags, then lay a clean rag in the bottom of the case, and have at it with the brake cleaner. Rotating a tire usually helps to get the entire carrier, spider gears and whatnot, (Put the tranny in Neutral if you have a locker). The rag in the bottom helps to soak up all the brake cleaner and speeds the drying time, as you're not waiting for a big puddle of brake cleaner to evaporate, plus you can take that rag and wipe down the gasket surface with it when you're done spraying the insides.
  9. divorced
    Jul 20, 2004
    5,115
    Thansk guys. I guess using a mixture of toilet paper, brake cleaner, and soap, I should be able to get it :D
  10. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    Yeah go ahead and wipe it off, will be hard to get it all but youll get the bulk of it. And brake cleaner is always what I use.
  11. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    several ways...
    I've used brake cleaner,or diesel fuel,laquer thinner,or similar solvent in a paint spray gun to wash out any chips after a bearing failed...gas works too--but be careful,it can ignite pretty easy in hot weather--NO SMOKING!!.. :weld:
  12. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    better yet... they make a pill for that.... :)
    anyhow.. put me on the brake cleaner vote.. that is what I use.... :wink1:
  13. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    BUT, be careful, if you use too much brake cleaner,,,IT WILL BURN!! :doah:
    it really hurts too i have been told. :D
  14. BiggerRigger
    BiggerRigger Registered Member
    Nov 3, 2002
    81
    C.D.A. Idaho
    The small red parts cleaner from harbor freight will fit right under the pumpkin. Aim the hose up into the top of the gear case and turn it on to check flow. Now go watch Trucks on Spike T.V. and when its over so is your diff. All clean and purdy like the day it was new.
    Aaron
  15. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    now thats a smart MoFo. I am going to try that next time
  16. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    front to back :wink1:
