How do I connect my fuel lines to the fuel pump outlets?
Discussion in 'The Garage' started by LoggieStyle, Aug 4, 2003.
  1. LoggieStyle
    LoggieStyle Registered Member
    Jul 10, 2002
    78
    Tujunga, CA
    I know this seems like a simple question but I really would like to know the proper way to do this. On my old carburated fuel pump there was just hoses running from the hard lines to the pump outlets held on with hose clamps. On my new in tank electric pump that I am using in my fuel injection conversion I was going to try to do the same thing but the vapor line has two small tabs, one on top, one on bottom that would prevent any hose of an appropriate size to fit on it, I would also like to avoid using clamps on the other two hoses if there is a superior method. Did GM use special connectors for going from hose to pump? If so where can I get some? Alternatively I suppose I could just cut the tabs off and make a hose fit, but that seems a little mickey moused and I don't want to play around with the fuel system any more than I have to.
    Thanks,
    Logan
  2. dyeager535
    26,980
    Don't quite understand what you are describing, but GM EFI engines all use threaded sender to fuel line fittings, at least that I've seen. /forums/images/graemlins/smile.gif
  3. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    I just had the guys at fuelsender.com rebuild/customize a TBI sending unit for my swap. I had them put in a 3/8" return line and remove the factory threaded fittings and bubble flare the lines so I could use rubber hose and clamps. I don't see anything wrong with this since one line is suction only and the other shouldn't have extremely high pressure. I have some Parker compression fittings that go to AN6 male adapters that I could use to hook the lines up to about anything.
