How do I correctly cut braided stainless steel fuel line
Discussion in 'The Garage' started by sickquad, Sep 28, 2004.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Like the title says. How do I cut this stuff to length correctly without messing up the braid. I'm doing this on a friends motor so I want it to look nice. I know I tape the section I'm going to cut, but what should I cut it with. A hacksaw seems like it may be a little aggresive.
    Anyone done this succesfully before?
    -Chris
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I wrap the spot to cut with electric tape real tight and use a cut off wheel on a grinder. you can also use a hack saw with a fine blade to cut it.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Use masking tape and a hack saw, cut through the masking tape.
    An air saw would probably cut it nice but doubtful you have one of those.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Duct tape seems to work the best, wrap tightly. Use an abrasive chop saw or a cut-off wheel on a hand held grinder. Be sure to flush out all of the crap that will end up inside the hose.
    Other option is if you have a Beverly Shear available, those work pretty well too.
  5. sickquad
    Jul 23, 2003
    785
    Ma
    Cut off wheel it is.
    This board is the best. You guys are the only reason I look like I know what I am doing.
    -Chris
  6. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Yup. I have done the hacksaw method. Difficult especially when cuttin through the rubber part. I've also done the sharp thin cuttin wheel route. Hard to keep straight. I do believe however that there is a hand held spinny wheel kinda like one used to cut flex electrical wiring except rotated 90 degrees. It can be done with either method I mentioned I'd done before. It's not the slickest way but with some patience it can be done.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    abrasive chop saw
  8. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    DREMMEL!!!!
