How do I drain my np203, oddball??
Discussion in 'The Garage' started by mofugly13, Apr 2, 2005.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I installed a Milemarker 502 part time kit in my 203 and then proceeded to top it off with gear oil. Right as it topped off, I remembered that the 203 is supposed to be lubricated with MOTOR oil. Argh, dumbass. So, I figure I'll drain it and start over. Well, theres no drain plug on the case. I looked in the factory manual, chiltons, and haynes, and the pics they have show a drain plug on the bottom. But mine does not have it. However, it does have the boss where a drain plug is supposed to be drilled. So, I am wondering if it would be ok to drill the hole, and trust that the escaping fluid will flush out any metal bits caused by the drilling. After it is drained, I'll tap it for 3/8 npt and run some more fluid through it to flush any more bits of metal out. Does anyone know if there is anything just inside the case where the drain hole, that I should be worried about while drilling and tapping?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you could take one of the bolts used to mount the transfer case to the adapter and that would drain a good amount of the oil in the transfer case
  3. chevy_mud_84
    chevy_mud_84 Registered Member
    Feb 28, 2005
    89
    Brockville, ON, Canada
    Take one of the bottom bolts outta the gear case cover on the back of the t-case. its that round cover on the back with all the bolts around it, i just take the bottom bolt out and it drains. Hope this pic works:
  4. chevy_mud_84
    Feb 28, 2005
    89
    ok sorry pic didnt work
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    As said you can take out one of the cover bolts. This pic is of a NP205, but the covers look similar. Take out the lowest bolt on your cover, the yellow circle. Also, here is a link that says the two bottom bolts http://www.4wheeloffroad.com/howto/47538/
  6. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Thanks, guys.
  7. BlazerFarm
    BlazerFarm Texagonian Premium Member
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    Just go get a hand suction pump with a vinyl plastic hose. That's what I used when I drained my 203 in the '76. You definitely don't need to drill any holes.
  8. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    I used to just loosen the rear cover bolts and crack it open, don't pull it all the way off cause those pesky needle bearings will fall out. Not really hard to get back on, just uneeded work.
