how do i drain my tank
Discussion in 'The Garage' started by shaun, Feb 14, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I have a hose hooked to my fuel line right before the filter going into a can and it only dribbles with the key on or off. We also tried hooking up a pump but it only pumps out air (we did this for about 3 mins) and I know i was almost full /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  2. dyeager535
    26,980
    If the engine isn't running, the fuel pump won't keep pumping. (now I'm pretty sure you mean the '90)
    There is a plug on the drivers side somewhere, disconnect that, and you should be able to "hotwire" that to make the pump work.
    If you don't like that idea, put a floor jack under the tank, with a large piece of wood (like thick plywood) to keep from ruining the tank, and drop it that way. As long as the truck isn't 4' in the air, it's not that hard, even full, just go slow.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Hey shawn try cranking it. The fuel pump will only pump for like 3 sec if the key is turned on unless the engine is turned over. IIRC it recieves a signal from the dist or something.
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Get a hose and syphion it out. How much fuel do you have in it?
  5. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I went to harbor freight and they had a fuel transfer pump for like $3.99. You stick one hose into the tank, one hose into whatever you want to put the fuel into, and then just give 1 or 2 pumps on the pump to get the siphon going and it transfers. Worked pretty good.
  6. shaun
    Apr 22, 2003
    745
    We hooked up this pump that the MK ordered from northern (some universal pump) and all that came out was the fumes no fuel. We ended up just lett ing it trickle all night. Its basically empty now woo hoo now to drop the tank. Thanks for all the replies. /forums/images/graemlins/grin.gif
