how do I figure out gears?
Discussion in 'The Garage' started by yellowmoon, Sep 16, 2002.
  1. yellowmoon
    yellowmoon Registered Member
    Dec 30, 2001
    94
    Modesto Ca.
    What is the easiest way to figure out what gears I have? I thought there was a way to spin the tires and count the revolutions of the drive line? I got one and a half rotation on the drive line (spinning one tire).
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes you can do that you turn the tire one compleat turn and count how many times the driveline makes a compleat turn and it is also stamped on the ring gear /forums/images/icons/smile.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Look fot a tag on the diff. cover.
  4. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Actually, you have to remove the diff cover and look at the numbers stamped on the Ring gear. That will tell you the number of teeth for both the ring and pinion, the ratio of which is what you are looking for. Do a search on this and you will find the key you need for number decoding (I don't know it).
    Also, if he goes the route of spinning tires, won't he need to spin both tires one full rotation at the same time (hence requiring a buddy or pissed off spouse)? I think that's the reason you're getting onle 1.5 rotations by spinning one.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    The D44 under the front of my Blazer has a tag attached to one of the bolts on the diff. cover with the gear ratio.
  6. bobsurf
    Jun 26, 2001
    410
    San Marcos, CA
    Wasn't trying to piss on your parade, I just don't think that's stock for most axles (never seen or heard of it before).
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I don't know how comman it is, but my Blazer was 100% factory stock. I bought it from the original owner. I asked if anything was done to the axles and he told me thier are the originals
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    GM put a tag on one of the bolts holding the dif cover on, on all of their 4x4 front axles. If it's not there, then the cover was removed at one time and the tag was never replaced.
  9. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I'll back Joe up on that one, I've seen lots of the tags. If they aren't there, they were removed at some point. The only foolproof way to know for sure is to look at teh stamp on the ring gear though. </font color>
  10. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    You gotta double that figure due to the open diff, so you have about 3:1 gears, id say 3.08:1 is what you have.
  11. bobsurf
    Jun 26, 2001
    410
    San Marcos, CA
    I stand corrected.
