How do i fill torque converter with trans fluid?
Discussion in 'The Garage' started by dodgetruck91, Jun 11, 2003.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    hello, im gettin ready to put my tranny back in and i need to know how im supposed to fill the torque converter wiht fluid and how much, its a 87 with a 700R4 Also, does anyone know where to get a gasket for between the trans and T/C thanks.
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    all u hafta do is pour a quart or so in the hole in the TC. not too bad.
    NITRO
  3. mudtruck
    mudtruck Registered Member
    Apr 2, 2003
    14
    pa
    pUt it in n and as for the gasket try napa it should be a round seal. Make sure you put a little grease on the seal before you slid the tc into it.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I put my TC back in empty. It will fill up from the pump quickly when you start it up for the first time. Wouldn't be a bad idea though. Just pour some in and make sure it doesn't spill out when you have it upright.
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    yep as everyone else said....
    grease the seal and dump a quart in the TC before you slide it in /forums/images/graemlins/thumb.gif
  6. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i just put a tranny in yesterday, and i just put it in dry and let the pump fill it up, is there really any problem with that?
  7. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Nope...just make sure you shift it thru all the gears sitting there to get the fluid distributed. Then shut it off and see if you need more.
  8. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    If you fill the converter it just helps get the air out quicker. Less filling after the initial fill.
